Ir para o conteúdo principal
Boot Loop after little fall
Hello, I had dropped my iPhone 5 for a small bed (a fall of about 50 centimeters). After that, my iPhone will not turn but:
1-When I plug Charger / PC: iPhone is on Boot Loop (Apple Logo and Apple logo and black screen and so on to infinity ...)
2-When I tried to restore iTunes shows me the error 21 (even in DFU mode)
  • Now the iPhone is locked to the recovery mode. I've tried all manipulations and I'm sure it is a hardware problem but what (I was told it was the NAND, is this true? I have no message error about nand or any other thing...)
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Here is the schema of symptoms :
[image|644032]
por
Great. What i said
por
Hey, The iPhone rework but he's locked on recovery mode and I have iTunes error : 3194
por
i am getting error 21 and error 4005
por
Adicionar um comentário
2 respostas
Solução escolhida
I don't think that's the NAND. Have you tried a hard restore?
How to Force Restart an iPhone 5
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yes I've done it with nothing still in apple logo boot loop
por
Try cycling the battery. Basically disconnect your battery, then re-connect. You don't have to take it all the way out
Substituição da Bateria do iPhone 5
por
I forgot to say that I dropped the iPhone in his front not the back. So, this is generally caused by the battery
por
It sounds like your battery may have dislodged when you dropped it. Have you opened it up and had a look?
Pontuação 1
1 comentário:
No, I've bring it to a repairer who have said that's a EPROM (NAND I Think) problem !
por
Adicionar a sua resposta
ilyesbouira será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 5,534
