Ir para o conteúdo principal
A HP OfficeJet 4630 é uma impressora jato de tinta colorida multifuncional sem fio.
Can't replace black cartridge
I've put two new hp 61 xl black cartridges in and the printer says there is a problem and the cartridge needs to be replaced. The first time I figured the cartridge was faulty and went and got another new one but two in a row seems unlikely and I'm wondering if something is wrong with the printer itself. What's going on and can I fix it myself?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Try cleaning the metal prongs inside the printer cartridge with Rubbing Alcohol on a Q-tip. Ink may be covering one of the connections, making the printer unable to tell if it's a compatible ink cartridge and if it works.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Can get the black ink out, it is tucked under the frame of the printer.
por
Adicionar a sua resposta
Garielle Brown será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 3,121
