Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
Is the EMC 2416 same as EMC 2415?
My iPad 2 is a model A1396 EMC 2416
I have to replace the battery
Is it the same as the 2415 for purposes of following the guides here on replacing the battery and reassembly?
Thank you.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
If your iPad model is A1396, then you have the WiFi + GSM Cellular device, not just WiFi only. Here is the guide for your device, it is basically the same except your device has some extra antennas at the top that you need to be careful of.
iPad 2 GSM
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,264
