Ir para o conteúdo principal
The iBook G3 was unveiled in July 1999 as Apple's portable computer for consumers.
What do I replace the original thermal materials with?
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Good question +
por
Thank you, I'll give that a go.
Randy
por
Adicionar um comentário
1 resposta
Solução escolhida
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
por
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
por
Adicionar a sua resposta
randy3833 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 2,369
