Ir para o conteúdo principal
My iMac wont start.
Hi
My old iMac G5 will not start up. I get the white apple startup screen when I turn it on, the black lines circulate at the bottom and then the screen goes blue - but then, OSX and the finder will not appear. The screen stays blue.
Any ideas or help would be gratefully received.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Start up using your system installation disk, insert disk and restart holding down the "C" key. Go to the second screen pull down menu and go to Utilities - disk utility and repair the hard drive.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi
Thanks. I will try this when i get home from work.
But i don't think it will help because i already reinstalled the whole system.
But i will see
por
Hi... sorry it didn't solve the problem...
Any other suggestions?
por
I have the same exact issue, did you ever find a solution????
Pontuação 0
Adicionar a sua resposta
Lasse Kristensen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,801
