Ir para o conteúdo principal
Home button replacement problem
Hello,
I am trying to replace the glass from my ipod touch. I have the front panel out and the glass from the plastic surroundings and I am ready to put the new glass on it. Now there is a small question. The glue that I got with my glass, also covers the place of the home button. Is it a problem that my home button is glued to the platic frame, so will there still be connection? Or do I need to take of the glue from the home button?
Thanks in advance
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
why is the home button glued to the frame??
maybe i didn't got it right - but when you glue it to the frame - how should it work??????
so, yes - remove the glue from the home button
Esta resposta foi útil?
Pontuação 0
maybe you had a cover on the glass that has to be removed...
Pontuação 0
Adicionar a sua resposta
Niek Bronswijk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,415
