Ir para o conteúdo principal
The Dell Inspiron 1100 was a low-cost consumer laptop released in 2003.
9 Perguntas Visualizar todos
left side keys on keyboard sticking
All of the keys on the far left side do not seem to connect until I pound on them. Then they stutter and repeat. Keys 1, tab,caps lock, shift and A are affected. After I use them a while, they work ok. I didn't spill anything on the keyboard.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try popping the key off of the keyboard and removing any particles and gunk you find underneath. If its a sticky film that keeps getting the keys stuck, clean if off using isopropyl alcohol. If this doesn't work you may need to replace the entire keyboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
clsunshine será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 216
