Ir para o conteúdo principal
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Perguntas Visualizar todos
Boiler replacement for the water screen screw
The screw hole in the boiler has stripped out. is there a replacement for the brass fitting in the middle of it? I saw how you removed it with the flat washer and a pair of pliers. Thank you for your answer.
Peter in Portland
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You can purchase that part right here:
http://www.seattlecoffeegear.com/Saeco-B...
Esta resposta foi útil?
Pontuação 3
1 comentário:
Where did you see how the fitting was removed with a washer and pliers? I have the same problem. The screw hole appears that it's stripped, although I know it isn't, it was never removed, it just fell out one day; due to corrision I suspect. But I can't figure out how to remove it.
Pontuação 0
1 comentário:
Hey Bob, try a US quarter, it's just the right size.
por
Adicionar a sua resposta
Peter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,986
