Battery Replacement Teardown Question
Is it possible to replace the battery on an iPod Touch 1G without removing the logic board from the body?
From the pictures it appears that there is enough room to get to the solder points while the logic board is still attached.
This would definitely speed up the repair and I just wanted to see what the purpose of removing the board is.
Esta é uma boa pergunta?
1 comentário
I noticed you never got an answer to this. Are you still having this problem?
por originalmachead
