Ir para o conteúdo principal
Pergunta encerrada
A block of fine black lines has appeared around my mouse pointer.
My mouse pointer has suddenly grown a block of fine black lines about 5/8" deep x 3/8"wide. It has also stopped working. It moves around the screen, but won't activate anything I click on. Re-seated the memory chips, zapped PRAM NVRAM & SMC, did a complete re-install after zero-ing out the hard drive. Still happens.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Do you have access to an external monitor? If you do see if the problem show up with it.
Many in this series had issues with the GPU chip. NVIDEA had a bad run of GPU's and Apple had a recall on them. But that recall has expired.
At this point I don't know if it would be worth the costs to replace either the screen or the GPU depending on what you discover plugging in an external display. Sorry ;-{
Esta resposta foi útil?
Pontuação 2
I asked close to the same question here, see if it helps you:
Has artifacts attached to the desktop icons and mouse pointer..
Pontuação 1
1 comentário:
I never got mine fixed.
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,866
