Charger port is loose
I have a HP Pavilion dv9000 and my charger port is loose and you have to press the power cable firmly to make it charge, How would I go about fixing this, Thank you!
Esta é uma boa pergunta?
This is a replaceable power port which makes your job easy its not soldered to the motherboard. All you have to do is tear down the laptop till you get to the point were you can see the port and remove it. and replace with a new one which can be found on ebay
http://www.ebay.ca/sch/i.html?_odkw=HP+P...
there is a guide on ifixit though it is incomplete it should help with the disassemble
Disassembling HP Pavilion dv9000 Logic board
Hope this helps
Esta resposta foi útil?
you may want to check that the screw that holds it down hasn't just come loose
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 4,223
