How do I fix a floorboard leak in a 2005 Equinox?
I have a 2005 Chevy Equinox and water accumulates on the passenger side floorboards
when we have a heavy rain. I've sealed the sunroof and checked for any clogged tubing, but it still leaks and I don't know what else it could be. Anyone have this problem and found a solution to it?
Update (10/13/2015)
The water is clear, so not antifreeze. I sealed the tub that comes down from the sunroof and plugged up all that looks like where a leak could be on the sunroof with silicone. Any other ideas?
Esta é uma boa pergunta?
3 comentários
scraviscrav, is it clear water, like condensation? any chance it could be antifreeze from a leaking heater core?
por oldturkey03
Everytime it rains my floorboard is soaked front and back but the seats are never wet. What could cause this problem in my 2005 Equinox?
por Sandy Glaze
I had the exact same problem but it wasnt from the sunroof. The water from the windshield needs to go somewhere during a rain. There is a huge drain located under the plastic under the passenger wiper blade on the outside of the vehicle. The hood needs to be opened to access this area. There are a few plastic holding clips and a screw that need to be taken off along with a really strange rubber seal. When more water rushes in than going out, it will literally flood the floor. I had about a half inch of standing water. It ends up draining near the center of the vehicle by the rear of the engine. I hope this helps.
por tom_patenaude22
