Ir para o conteúdo principal
Lançado em 22 de agosto de 2013. Identificado pelo número de modelo NP940X3G.
How to upgrade SSD?
I've opened the back cover and removed the battery, but I see no mSATA. Where is it?
Update (09/25/2015)
Please see the pictures I've posted of the inside of the Ativ book 9+. Is there an mSATA SSD in this laptop?
Update (09/25/2015)
Imagem
Imagem
Attached pictures.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
i cant see any mSATA on this board. There is a place where it says 2nd SSD but as far i can see there is no connector. I think it is not possible to build a SSd with mSATA in this Laptop.
Sorry to say that.
Esta resposta foi útil?
Pontuação 1
Hy William
When you open the Notebokk, is there a orange cable on the left side of the Batterie?
if yes, under this cable, you will finde the mSATA connector.
Greetings
Daniel
Pontuação 0
2 comentários:
Unfortunately, no orange cable. There is a piece of plastic, looks like a spacer. There are two wires connected to this piece of plastic, very thin wires look like power, red and white.
If it is possible to post a picture here, I can share a picture of the inside of the laptop.
por Compartilhar
You can ad a picture by making a new answer and click the picture button
por Compartilhar
Adicionar a sua resposta
William Beldham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 40
Ao todo: 5,635
