Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 Perguntas Visualizar todos
System not reading games?
I went to toys r us bought my son a brand new game. Came home and he tried to play it but when you insert it into the system nothing shows up. The screen is working the buttons all work, camera is working so i try an old game, one i know was working same thing its as if there is no game in the system even when there is one?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
The cartridge reader is probably bad. It either has bent pins or it could have been returned from someone else with possible liquid damage or something. If you just bought it, I would return it asap and just get a new one. The cart reader is a pretty easy fix as long as your soldering skills are decent but why go through the trouble when you can just return it.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Mine was reading games just fine until it was dropped. Everything works just fine except it won't read any game cartridges.
So assuming thing is outright broken, its just a matter of looking for a broken solder connection or finding the bent pin(s)?
por
There is probably a bent pin inside which is almost impossible to fix. Just buy a new reader and solder it in place of the old one. I know this is late but I missed my fixit buddies :)
por
Adicionar a sua resposta
brian schneider será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 472
