Ir para o conteúdo principal
Repair information for the second iteration of the Aspire S7, the S7-392. This is a premium 13" ultrabook laptop computer made by Acer.
10 Perguntas Visualizar todos
RAID/HDD Intermittant boot up Failure
Ok, hope for some advice here. This is new for me!
Customer brought in an Acer Aspire S7 saying for a number of months the system has failed to boot, suspected that the HDD wasn't connected fully, these boot failures had been intermittent.
I have checked the physical hdd and all seems ok (as manufacturer intended, not one bit of tampering)
But on boot I get a warning and an option to press CTRL+I, if I don't it seems to boot normally on the occasions I have tried but if I press CTRL+I I get the screen below.
Note: Option2 is "Delete RAID Volume"
Any ideas?
Thanks in advance for the advice!!
Will
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Pergunta mais útil
Will I have just had the same issue with an S7-391. At this stage the only fix I could do was to replace the SSD as the RAID 0 was corrupted and everytime it booted Win10 said it detected a problem and would repair it then reboot to face the same issue. I am still trying to recover the data with no luck as yet. So I would suggest before you do too much more is copy all the data off first then reformat the drive or fix the raid array. I hope this helps as doing this I thought I was reasonably secure by backing up my stuff but now can see Windows had stored files that I do need all over the place and not in the folders I backed up.
cheers
David
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks David! Yes - same, cannot recover the data as yet.
por
Hi, I am also currently facing the same issue. I booted Ubuntu and performed extended SMART scan using the disk utility - the status shows OK. Did you guys ever managed to fix this?
por
Hi All
My wife's S7/391 has just shown the same problem. The error was in the second block and nothing would repair it or allow the device to boot up the Windows 10 operating system.
What I did in the end was to generate a Boot CD on another computer (Windows7 Ultimate), and use this in an external usb DVD drive to boot the Acer in Win7. This gave me access to the files in the Acer which I copied to a USB stick.
Once I had the personal files backed up, I deleted the raid configuration, (along with all data and programs), and repartitioned/formatted the SSD as two separate hard drives, C and F. Windows 7 was then installed in C and data stored in F. (I consider Windows7 an upgrade from windows 10 ).
(Note: I also changed the boot configuration in the BIOS to Legacy ).
This reply is being written on the rejuvenated Acer and there are no errors yet - time will tell though.
Ron
Pontuação 1
1 comentário:
I wonder the practical aspects of having a RAID 0 in the same SSD, since I got an Acer with factory default working with RAID 0, same configuration, same issue.
For my understanding if a partition is lost, all data is lost.
So unless RAID0 provides a big speed boost or performance improvement (since we are spending 50% of disk space to make this RAID0 artifact) , I would say your solution is the most logical and cleanest.
por
I have the same problem only now i cant get the recovery or acer to come up when i hit alt F10 it asks me for password and i never set one!The only options available to me in the sae menu that u have a pic of here is Delete RAID options wont let me pick any other options!
PLEASE HELP i think i may need to recover OS Completely almost was going to boot to a iwndows 7 disk with external drive and was then gonna upgrade back to Windows 8 then posssibly do drivers and apps manually???
Pontuação 0
A friend of mine recently faced the same issue. The Raid 0 set up of the 2x128 GB shows that there is an error with one of the drive. I only have option 2, 3 or 6. It is from an Acer Aspire S7-392.
Running Ubuntu disk check shows that SMART test passed for both drive in Extended scan mode. Since it's not a regular SATA port (it's an mSATA) - I guess i need to use an adapter to plug it to my desktop - and then I don't even know if it reads since my desktop is in AHCI mode.
Any help welcome.
Pontuação 0
Check out this link: ​https://www.data-medics.com/data-recover...
I've had a similar problem happen recently with my Aspire S7 392 and am searching for a solution to recover the data.
It's completely doable apparently!
Just pricey. I'll do a little more research to see if I can figure out a cheaper solution
Pontuação 0
Adicionar a sua resposta
Will será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 2,804
