battery not charging when plugged in and powered up
How to fix battery not charging when plugged in and in use
Esta é uma boa pergunta?
Depending on the tablet, the battery might of taken it's last life.
Try holding the power button down for 30 seconds, and leaving it plugged in overnight?
If the charging light is flashing or not on, the battery or charging port has failed or is broken.
(PS. If you remember that it's normal to be flashing while charging, then do not consider it faulty)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 240
