Ir para o conteúdo principal
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
My pc did not recognize my LG G3 D855
HI ALL
I HAVE LG G3 D855 WHEN I POWER IT ON I GOT A MeSSAGE " BOOT VERIFICATION VERIFY .
I WANT TO RECOVER IT BUT WHEN I CONNECT IT TO MY PC BY USB CABLE IT IS NOT DETECTING I TRY SOFT AND HARD RESET BUT NOTHING.
THANK YOU ALL FOR HELPING.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
I have this problem too. My pc does not detect my Studio 6.0 HD phone when I connect it. So far I have been unable to download any picture via USB cable.
por
Hello Friend
SO FAR DID YOU FIND ANY SELUTION?
THANK YOU
por
maybe...
go to website of lg. go to service - update software. download and folloew all insturktions for updating software, so you get the newest drivers and how you have to connect.
or
set the usb-connection to different modes
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello tdye08,
Try to enable USB debugging first,
  • From a Home screen, navigate: Apps > Settings > Developer options.
  • Ensure the Developer options switch (located in the upper right) is turned on .
  • Tap USB debugging to enable
If Developer Options are unavailable,
navigate: Apps > Settings > About phone > Software info then tap Build number seven times.
Cheers!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Friend
so i cano't arive to this situation.
Thank you
por
Got it. it seems to be your boot partition corrupted. you will have to flash you phone or update firmware from SD card if available
por
Adicionar a sua resposta
tdye08 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 6,662
