Ir para o conteúdo principal
The ThinkPad Edge E530 by Lenovo is a business market targeted laptop. This model has a 15-inch display that has HD+ Antiglare LCD, up to 1TB or storage, max memory capacity of 8GB, and a 720p HD webcam for video conferencing.
11 Perguntas Visualizar todos
E530C screen L hinge seems to be broken
it appears mine was dropped, computer functions fine with the exception if I move screen by hinge, I get momentarily disconnect until I position the screen.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You've probably broke the hinge from the plastic , If your comfortable taking your laptop apart you can strip it down to the hinge and use jb weld to repair it its a two part epoxy that make a strong fix.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Barry será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,108
