Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
Esta é uma boa pergunta?
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
por Noah Ackerman
