Ir para o conteúdo principal
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
How do I fix the door?
My passenger side door is stuck, how am I suppose to get the panel off if it's stuck?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can you clarify what part of the door is stuck? Was it hit and won't open? Will it not unlock? Did someone super glue the door shut?
por
Adicionar um comentário
1 resposta
Solução escolhida
i am a mechanic and this is one of the most tricky things to do depending on the problem. all you can do is move the seat as far out of the way as you can, get as many retainer screws as you can see out, and try to gain enough room to get your hand between the door panel and the door, and try to get on a lock rod or the door latch itself. make sure the door is unlocked even if the rod looks like it is. it takes LOTS of patience, but you can get it if you take your time. best of luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
amanda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 2,514
