Ir para o conteúdo principal
blinking apple logo nonstop
my daughters itouch has been down for sometime now and now it just blinks the apple logo, how can we get out of this?and restore.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Hold power button and the home button for ~10 seconds to hard-reset. Specifically, what led up to her iPod dying?
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
fluid damages are pretty bad - and they are getting worse.
when the fluid is gone - it leaves a conductive residue - this residue will act like cancer, it simply "eats" his way through the small parts and circuits.
you can try to fix it with cleaning.
get some isopropyl alcohol and a paintbrusch, disassemble the ipod and clean the odd looking parts (white greenish residue) - clean it carefully - but it must be removed, check the connectors and don't forget the bottom side of the logic board.
let it dry - don't use a hair dryer for that and when it's dry, reassemble it and try to power it on/connect it with the computer
good luck
Pontuação 2
4 comentários:
how do i open the itouch
por
oh i have my daughter itouch on the itunes and usb cord mode and nothing else happens
por
on the right side of this page is menu - click in step-by-step guides and use the one for the logicboard. and please - stop trying to charge it - it won't help and could finally kill the device!
por
If it has been water damaged and the Apple logo is just blinking, those are signs of possible hard drive or logic board damage.
Pontuação 0
1 comentário:
There is no hard drive in the iPod Touch, but a bad logic board is likely.
por
Adicionar a sua resposta
bunny será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 4,316
