Ir para o conteúdo principal
These white headphones are equipped with a remote and mic, and come with Apple's music players and iPhone. They are also sold separately. Released on September 9, 2008.
6 Perguntas Visualizar todos
Can the remote on these headphones be repaired?
I just recently purchased Apple's in-ear headphones. Not the ones pictured here, but the ones with the rubber noise canceling buds. I wore them in the rain the other day and now the microphone isnt working and the volume + and - buttons are not working. Oddly enough, the Play-Pause center button works just fine. Being that these are pretty expensive and cannot be returned due to my negligence, I wanted to know if this tiny remote can be opened and cleaned up?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
that doesn't sound good (no, thats not a lame joke - lol)
i never had those fancy headphones - can you see any "seam" ?
if there is something to open them - get some isopropyl alcohol (>90%) and a paintbrush (i know you like them much) and clean the contacts & switches.
but since it's an apple product, it would not be that easy to fix, maybe they casted/sealed/glued the thing a few times together.
but there might be another thing - get the "old" ones from ebay - they are cheap (and most likely fakes) - remove the earbuds from the cheap ones and place your in-ear pieces on it.
it would be still a tough job but way cheaper than a pair of (still chinese) headphones for 80 bucks
good luck
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanks Markus. The remote has a seam, but like you said, it might be sealed so if I try to pry them open the remote might completely break..I'll give it a try. I will keep you posted.
por
Ahhhhh, I finally get to use the paintbrush and alcohol combo. LOL
por
i knew it ;-)
por
can u describe how u fixed it? i have the same problem. i took them out on my bike, it started raining, now the sound works but the play/pause and volume buttons don't work.
Neerav
Pontuação 0
Adicionar a sua resposta
Majesty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 6,590
