Ir para o conteúdo principal
HP Elitebook 6930p announced in September 2008 and was one of the first generation EliteBook laptops. It was advertised as the first laptop to break the 24 hour battery life barrier.
18 Perguntas Visualizar todos
Screen blackout when moving cover
When I move the Screen up and down the brightness goes down for no reason, even with small move the brightness goes down, and sometimes it goes off it becomes all black like it's closed even when it's open.
I think it's a hardware problem i'm sure of that, cause the problem happens when I move the cover with just a slight move, it goes black and I had to move it again back and forth to get its brightness back
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
there is a light indide your screen it may be loose.
Esta resposta foi útil?
Pontuação 0
1 comentário:
could it be fixed ?
por
Adicionar a sua resposta
Mohammed Bouzaid será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 236
