Ir para o conteúdo principal
Manuais de reparo e suporte para carros e caminhonetes fabricados pela Chevrolet, uma divisão da General Motors.
1367 Perguntas Visualizar todos
key stuck in ignition of old truck
The ignition key mechanism won't turn off or release key. I have been removing fuse to shut her down... It is stuck in "on." Turning of the steering wheel to relieve locking does not seem to help.
Any suggestions would be appreciated
Scott
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Have 88 gmc truck key stuck in ignition in on position and won’t come out tried everything disconnected battery to start power
por
I've had the same thing happen, I've had luck twisting the key partially int the start position the back to off. the permanent solution is a new ignition cylinder
por
Adicionar um comentário
3 respostas
Depending on the year there is a small hole which you stick a paper clip into next to the key hole. Pushing the clip in and turning the lock set toward accessory will allow the whole lock set to be removed.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Then you can push the key out from the back side of the lock.
por
Some old cars with the key on the steering column would ‘lock’ the key in if the wheels were turn all the way to the left or right, such as when parallel parking. You had to pull the steering wheel real hard in the opposite direction while simultaneously turning the ignition.
Pontuação 0
1 comentário:
Have 88 gmc truck wheels r straight and turn and key will not turn off
por
Do as Frankie advised you, I had the same problem a few years ago and that did the trick.
Pontuação 0
2 comentários:
My "new" 88 GMC C1500 just started doing this. Will the steering wheel yank work forever or do I need to replace ignition or...?
por
How do you fix that on 1998 silverado c1500 have to turn wheel Wich is hard all the way to the left to turn over the key and when you do hearing clicks
por
Adicionar a sua resposta
redhare será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 38
Últimos 30 dias: 140
Duração total: 13,721
