Ir para o conteúdo principal
After Repair: Home button working, Touch ID not
I just finished swapping my screen after two cracked ones and a malfunctioning one. After these three fixes, everything was working perfectly fine (except for the screen on the last two changes; bought from the wrong person I guess). Now, after putting in the newest screen (and having to readjust the cables as one wasn't in all the way, making this newest screen malfunction…) Touch ID is no longer working. When trying to activate it, it sends me to a "Failed" screen immediately after trying. Does anyone know what this problem would be? I've tried readjusting both Home button connections and nothing seems to work. If I did damage it, can you give me a link to the part I need to repair it? Thanks for any help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
You have to use the OLD home button. I f your new screen came with camera and home button already installed, that is usually the case.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It is. That's the problem.
por
could you be more precise? what IT IS means - you tried it or it comes with home button?
por
Try to reset the touch ID. Your old touch ID data has been disable after screen replacement.
Pontuação 0
2 comentários:
How'd you go about doing this? Is it something in the OS or the hardware?
por
Just reset everything. Nothing. Any other ideas?
por
Your Touch ID is linked to the device you can't replace with new button without loosing the Touch ID function.
Pontuação 0
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 378
