Volume not working / Remote volume buttons turns off tv
My Samsung Series 6 (6000) 50 inch volume does not work. The television does not have any buttons for volume so I have to use the remote.
Whenever I push the volume up and down buttons on the remote the television turns off or on after a delay. There is no way to get the volume to turn up. There is no sound.
Do you have any idea how I can fix this or what I need to replace? The television screen works fine.
And just for information purposes - the remote works fine it seems to change the channels so I'm not sure if it is a remote problem or a television problem.
Esta é uma boa pergunta?
7 comentários
Did it ever work? Is it the original remote? If not, what remote is it?
por David Keldsen
Yes it worked until it stopped working. It's the original remote. Everything worked fine. Then it stopped working. I wonder if the tv got wet or something. I used to have it placed next to a window that I left open and maybe when it rained it got wet. Everything else works fine except the volume doesn't increase when you push the remote button. Instead the tv turns off.
por brookskevin940
Which model you have? 6S EH, F, G or ?
por Buddhika Mahesh
Its a model E.
CORRECTION: The remote is a time warner cable remote. The samsung tv remote does not allow for volume to work though.
por brookskevin940
I have the original remote. This Tv came in our travel trailer when we bought it and has been nothing but problems. If you hit volume up or down, change channels, or change sources it powers itself off. TV does not have any buttons so I am at the mercy of the remote.
por luckey4u2
Exibir mais 2 comentários
