Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 Perguntas Visualizar todos
Kenmore 110 will not power on.
Washing machine will not turn on, no selections will work. GFCI power outlet was tripped, I reset the outlet and it does have power. Tried different outlet, same result.
Is there a reset button in washer or any fuses. Made sure lid was fully closed.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
2 respostas
Pergunta mais útil
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Reading around it doesn't look like there are fuses that need to be replaced or some reset switch.
I haven't had experience with this specific washing machine, but there are some forum posts out there that look like they have had the same problem. Here's some instructions that look useful.
Good Luck!
Esta resposta foi útil?
Pontuação 1
your forums sucks donkey dicks
Pontuação 0
Adicionar a sua resposta
Bob Johansen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 4,137
