wont sync or charge
i phone 3gs 32 gig wont sync or charge after screen being replaced opened it back up all connections solid any one know if jailbreak could cause this or did a part go bad i tried everything
Esta é uma boa pergunta?
open it again and check connector no. 4 - it connects the dock with the logic board.
you can use the dock connector guide for that
Esta resposta foi útil?
did you try to reset it ?
press and hold the sleep and the home button at the same time until the phone restarts - this could take around 10 seconds.
i know that you wrote that all connections are solid - but number 4 can be *aaaaaarrrrrghhh* - sinc ethe 2 problems are dock related, i would always check number 4 ;-)
Do this: http://support.apple.com/kb/HT1747 (the guide)
and then take a toothbrush and clean the contact on the iPhone.
This helped me!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,285
