Wont charge at all
My nobis tablet wont charge at all even if i hold it it been a while since i used it
Esta é uma boa pergunta?
Hi Darlene,
Try using a different cable to charge your tablet. If this does not work, it is most likely an issue with the charging port. Its actually very common on this model of tablet for the port to come loose and stop charging and many people have reported an issue with it.
It's worth a shot to open up the tablet and reseat the charging port or check its connectors to make sure everything is as it should be. There are a couple student guides on the NB07 that could help you get inside the case: Nobis NB07
Esta resposta foi útil?
I did try a different cable and charger it still wont charge
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 388
1 comentário
I can't get it to turn on
por Robert Stark
