Shift key not working
I have a Hp 15 and both shift keys are not working.
Esta é uma boa pergunta?
Plug in an external keyboard, do they work now? If no, try the steps below.
Go to Control Panel then look for Ease of Access
- Click on Change how your keyboard works.
- Uncheck where it says Turn on Sticky Keys and click OK.
If this doesn't work try checking the keyboard language if set correctly.
- Go back to Control Panel then look for Region and Language and make sure all tabs at set to the United States.
- Click Apply when a change is made then try your keyboard again.
If these tricks don't work, you will need to replace the keyboard.
Esta resposta foi útil?
only one of mine isnt help/ see it does this when i do question /
nope, doesn't work at all
I put up with this for a while, using caps lock. Then got fed up so proved that it wasn’t Windows by booting Linux, just the same on there, so decided to get a new keyboard. Opened the laptop to check the part number of the keyboard. I then thought what about the connector. So I removed the ribbon cable gave it a clean brushed out the socket it went into and put it back together.
It now works perfectly!
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 27
Ao todo: 14,066
