Why is my phone screen stuck on "BLU"?
How do I fix my phone screen when its stuck on "BLU"?
Esta é uma boa pergunta?
try factory reset
Turn off your cell phone.
press and hold Volume Down + Menu button + Power button.
If you see menu of Recovery mode, then release your fingers from the phone.
now select "wipe data/factory reset" using Volume buttons to navigate, and Power button to choose.
Afterwards accept operation "Yes -- delete all user data".
select "reboot system now".
Done!
Remember you will lose all your files and data
Esta resposta foi útil?
That didn't work my phone still looping
then you have to re flash the phone with stock firmware....
when i do that i don't see factory reset or wipe data
tell me what you see ... or a screen shot will be much helpful
I had to call and get mine replaced
It happen to me when my phone was stuck on the blu logo I flashed it and it was back to normal for a few day .It started happening again it stuck in the Blu logo and won't come on I guess flashing it hasent helped what else can I do ?
My phone is too, stuck on the Blu logo and I really upset, because I wish to use that phone but I can't boot it
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 23
Duração total: 13,065
3 comentários
The phone stuck on blu logo
por Sandreen brown
Mine was too, until I took off the plastic cover on the screen
por Kali
I have the same issue is there a way to get my files before doin factory reset
por Tigest
