Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone xr. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 6.
iPhone 6 died suddenly and won't turn on.
Dear ifixit family,
I recently got an iphone 6 which was working quite nicely up until 2 days ago when the phone turned off, and when I clicked the home button, it showed me the red battery logo and the cable logo. Upon which I connected it to a charger, and the cable logo disappeared. Thinking all was fine, I left the phone to charge for almost an hour, and tried turning it back on.
And my blood ran cold. No response from the phone. Tried the home+power button routine. No dice. Left it on charge for a further 3 hours and tried all the possible combinations including holding the home button and connecting it to my mac. Nada.
It's been almost three days now and the phone isn't recognised by my mac nor is it turning on. Please help. I've had to go through a LOT including letting my client enslave me for 3 months. *sob*
Esta é uma boa pergunta?
Pontuação 66
58 comentários
وقد جلبت هذه المشكلة حتى في الكثير من الأحيان
por
Your not alone ive had this twice with iphone 6 plus
por
I wont be getting any more iphones my wife has a galazy note 4 its been through !&&* and back and still works fine and yet a most looked after iphone dies for nonreason really dissapointed
por
i had the same problem, replacement of the lightning connector assembly solved the issue
por
How much did that cost Yu
por
Exibir mais 53 comentários
Adicionar um comentário
23 respostas
Solução escolhida
Hey Aryan,
first of all, I'd recommend going to an Apple store to check if they will replace your iPhone for free. It's almost always the best option since you don't void your warranty early on by doing something as simple as replacing a battery.
Now, if you're out of luck and you want to get repairing, ask yourself if there were any irregularities before. Heating up when charging, quick battery drain etc. Also did you charge the device with the original Apple USB cable, in an original Apple charging plug?
I would recommend for you to try the following (in this order) :
- replace the battery, if the phone turns on check if the battery charges. If yes, problem is most likely solved, if no, go to step 2
- replace the dock connector.
If none of the above work, please contact me.
You could also check the iPhone Won’t Turn On wiki and go through the checklist there.
Good luck!
Imagem de Replace a 1810 mAh battery compatible with iPhone 6. Battery installation adhesive is included.
Produto
iPhone 6 Battery
$29.99
Esta resposta foi útil?
Pontuação 13
40 comentários:
Dear Paintskill, Thank you for the info. I haven't been able to go the store yet, but will keep you updated.
por
Hey I tried the above steps and it didn't work for me. Both the dock connector and the battery were replaced and also tried and other screen and still didn't work.
por
was there any solution to this problem. i got a iphone 6 with the same problem.
por
I am fixing a phone for a customer, He said the phone was thrown half way across the room against a wall. It worked fine for a few days then one day he plugged it in, it got really hot and turned off. I have tried replacing the LCD, Battery, and the Charging port but still cant get life. Anyone have any ideas? I'm thinking the motherboard is probably shot...Let me know what you think please.
por
Hi Turice9,
Sorry for the late response, been very busy lately. Try to remove the battery and plug the phone into a charger. If it remains "dead" and keeps heating up the motherboard might be damaged.
por
Exibir mais 35 comentários
Pergunta mais útil
My phone did this same thing today. Just went black and I could not wake it. Charging it provided no response. I plugged it into my computer and no response and the computer did not see that the phone was connected.
I found on the Apple website to try holding down the power button and home key simultaneously for 15 seconds. It worked !!! My phone woke up and so far has been working fine. Maybe others are having a similar issue.
Pontuação 37
42 comentários:
thank you so much for the 15 seconds suggestion.. got my phone awake..so happy..God bless you..
por
I tried this too, (hold down the power button together with the home key for 15 seconds and then it worked! Thanks.
por
just happened to me and the 15 second method worked for me too!
por
worked for me to. Had to hold both buttons down for a full 15 seconds though.
por
worked for me too. thanks a lot
por
Exibir mais 37 comentários
If you have replaced battery and dock, Fast battery drain, red screen, and sudden death are all very good indications of a short.
More often than not the short is the tristar IC (1610A2), which becomes damaged from using cheap wall chargers, car chargers, ipod docks, ect.
The issue is board level, and its impossible to know if the issue is this ic or something else on the baord. Your best bet is to send it to someone for board level diagnosis or repair. There is a link on my profile to a website that will help you locate some of the most trusted board level techs there is. There may even be one close to you. If not, all of them accept mail in repair.
Sudden death on the iPhone 6 series is common, and it can almost always be fixed, but only by experienced board repair technicians. I fix many of these each week
Pontuação 14
9 comentários:
Do you know any european board repair techs also?
por
@rany is in lebanon
por
Can you fix mines because I tried all of these
por
how much does it cost to try to repair tristar IC (1610A2)? Can you fix mine or Know anyone in Montana?
por
you can find very qualified people who can replace the tristar all over the world at http://boardrepair.info
por
Exibir mais 4 comentários
I found this guide, which might be helped.
https://usefulpcguide.com/18200/my-iphon...
Pontuação 4
2 comentários:
The link given above was a great help for me.
por
Thanks! This link was helpful- but unfortunately had to reset my phone. was having other issues before, such as backing up photos for the past 3 months even with icloud and iTunes- so now they're all lost :( But at least the phone is up again! I'm considering getting an Android phone next, but they all seem to have issues too. So frustrating
por
I held down the phone's right hand side power button and the front home button at the same time, for about ten seconds. Then the Apple logo came back on the screen, and after a few minutes I was able to redo the set up process. I had tried that previously without success, but I hadn't held the two buttons down for long enough - it took about 10 seconds before the phone eventually responded.
Good luck, I know how frustrating problems like this can be!
Pontuação 1
I’m using Iphone 6+. I can’t turn on even I hold the button of HOME and POWER ON/OFF for 30 seconds while it’s charging of course. Even I clean the chord or my iphone or holding buttons everywhere nothing works. But it really works 100% it needs HEAT. I put it in under my laptop when it overheats and then tadaa it opens. I don’t have hairblower, radiation something, don’t have a car, and worst I don’t want to put it in a microwave or stove just to heaten the back and the front of my Iphone 6+. But the problem is if I unplug the charger of my iphone and then it goes to back to the logo of One Red bar logo charging something like that. My battery was drained for 51% and needs to replace a new battery. I was really stupid for using my iphone while playing so don’t be stupid as me. But I’m telling you it really works it needs HEAT and if you want to fixed it instantly you just buy another new battery that’s all.
Pontuação 1
2 comentários:
I'm from PH and it's outbreeakk so TAKE CARE OF YA'LL. BE SAFE.
por
This worked for me. I have an iPhone 7 Plus and it just died suddenly. I followed this and placed my phone on the vent of my laptop for a few minutes until the phone was hot. Once the phone was hot enough, I plugged in the charger and voila, the phone started up and the screen lit up again!
I thought the problem was solved and since the battery percentage was 99%, I unplugged it and left the phone for a while. When I came back, the phone was back to the black screen again but I still feel the home button vibrating whenever I press it.
Maybe I should get the battery replaced. The battery health of my phone is 76% BTW.
I'm from the PH as well. Can I know where did you get your battery replaced and how much did all of the repair and replacement costed you?
Thank you so much again for suggesting this solution. Will be waiting for your response. :)
por
hi Unfortunately i experienced the same issue a couple of days ago. I took it to Authorised service agency & was shocked to know that it will have to be replaced. The ASA is not even giving proper answer for the glitch which caused iphone to go dead.
Does anyone have any support in mumbai?
Pontuação 0
When your iPhone won't turn on,you can use iTunes to restore it to normal,but this way will case your iPhone data losing.However,I recommend you use this iOS System Recovery to restore ios system to normal without data loss.
Learn the guide:How to Fix an iPhone That Won't Turn On
Pontuação 0
last night my mobile had finished charge when i pluged my mobile show then icons but it does nit work then i change the charger cable but then no show anything on the screen
help me
Pontuação 0
i was travelling and all was happening well den i played my music aftr a min or 5 min it got off . and its not undr warrenty i have tried to connect charger den also it wont gets start ,den i preses power + volume down and home button ..nothing happened .wat to do ?
Pontuação 0
I bought a brand new cable and charger from Apple and it resolved my issue. The iPhone 6+ I use can only charge from the old charger when it is already turned on, no longer when it has no battery. It has the same issue with several non-Apple cables as well.
Try using both a new Apple cable as well as a new Apple charger to see if your issue is similar.
Pontuação 0
my iPhone 6+ is very old i got in three years ago and i lost it for about a year and i got it to turn on and now every once and a while it just turns off the screen fades and slowly goes black but it will still play music for a while until it completely shuts off and wont turn on ive tried holding power and home button for long periods charging for hours and it wont turn on then sometimes if i hit the power button it just turns on and works fine
Pontuação 0
I held down the power button and home key simultaneously for 15 seconds. It worked !!! My phone woke up and so far has been working fine. Maybe others are having a similar issue
Pontuação 0
Crap phones. Notice how the old phones go to crap when a new one comes out. My 6s does this weekly. Becoming a problem. I use the alarm quite a bit. When it crashes at night, no alarm. Won't be purchasing anymore Apple products. Been a good phone for 3 years. Crap now.
Pontuação 0
1 comentário:
You've had that problem too huh? My dad's alarm's on both his personal iphone 7 plus, and work iphone 7 have frozen when he hits the snooze button. So hours later, past the time we were supposed to leave, luckily my dad naturally wakes up, but it is still late. This caused many wonderful days of extreme tardiness at school.
por
First thing you need to do is find out if the phone charging. You can buy a usb amp meter (very cheap) http://amzn.to/2DXxScM and check if the phone is drawing any amps. Anything between 0.2 to 1amp is good and means the phone is charging as it should. Your problem could be a display issue where the phone is working but not able to display an image or backlight to the screen. This is caused by either a short on the 5.7v rail or the display chesnut ic. You can see a video here that talks about how the 5.7v line works. https://youtu.be/qy7FwDgWvnQ
Pontuação 0
Hey, I have the similar problem on my iPhone 6s. As I used it battery went weaker and weaker, I thought that's the common problem with Apple products so I went to the local repair shop and I changed battery. When I went home my battery was still weak and was draining fast. I thought that he didn't replaced it so I went to repair shop and he replaced it again, and the same problem. He change the connector port, and the same problem. My battery would die after 3 hours, and I always had my phone charged on. One day i left without my charger, and I got one from my friend, stuck it in my iPhone and that red icon was on, but it wasn't charging, and the battery completly drained out. I really can't afford more repairs, it already costed me more than 100$. I treid the home button and main button for a minute, nothing happens. I really need al the help from you guys. And for the record my iPhone never droped, or had any damage, never heated up, really don't know what should I do??
Pontuação 0
1 comentário:
Did you get an answer. I'm having the same problems.
por
My iphone 6s was on 100% when i went to school, and i wasn't on it AT ALL this morning and i tried turning it on in second period and nothing And then a really dark blue screen came up then went to black, I turned the ringer off and on and i felt the vibration and then when I got home It wouldnt wake up I put it on the charger not even the battery icon came up.... Im so confused i did absolutely nothing
Pontuação 0
1 comentário:
same i whent a baseball game today and when i was leaving it would not turn on
por
Hey guys check out latest iphone accessories here….you could get a new charger here
https://ps-mobile-phones-accessories.mys...
Pontuação 0
Hi my phone died for 2 days it just suddenly turned off while I’m playing Mobile legends then won’t turn on even after doing the home/power button hold, even charging it didn’t help. Now, it suddenly turned on after 2 days. The phone mysteriously turned on. Before it i had my phone checked up by a technician he opened the phone and said it will be hopeless to repair the phone but then the phone turned on after hours of checking the phone. Can anyone explain this?
Pontuação 0
1 comentário:
your phone battery in the back of the iPhone is droping you need to get apple to look at it
por
I know one software can solve your problem, FoneGeek iOS System Recovery , it can fix various iOS problems , such as iPhone stuck in recovery mode, DFU mode, Apple logo, headphone mode, spinning circle, boot loop, iPhone black/blue/red/white screen of death, iPhone frozen/locked/disabled, iPhone won't turn on, and more.
Pontuação 0
I use an iphone6+ and it went flat yesterday i tried charging it but it showed a red bar and i plugged it all through the night but it would not come on
Pontuação 0
my phone died and i tried charging it but no red charger will come on. i tried holding the home button+sleep button and nothing has been working. SOMEONE HELP ME ASAP
Pontuação 0
1 comentário:
My iPhone 6 suddenly went off but I could vibrations and sound whenever I get a meddage. I tried restarting and now it won't even turn on. Tried charging it for an hour but still and I removed the battery and kept it back but still won't turn on.
Please I need help
por
Threw my Iphone away and bought an Android phone never looked back... anything with a mediatek g90t to a g99 is really affordable. A Poco m5 with a mtk g99 set me back 100 $ but is well worth it... my old note 8 pro with a g90t is still going strong and hasn't slowed down with today's apps (I did replace the battery as it is 3 years old)... my old Samsung Galaxy tab a p205 has the suckiest chip of all my androids but still functions well! Now I have 3 devices that aren't even close to the price of an Iphone... no regrets...
Pontuação 0
Adicionar a sua resposta
Aryan Sharma será eternamente grato(a).
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 51
Últimos 30 dias: 284
Ao todo: 891,885
