Ir para o conteúdo principal
Lançado na primavera de 2014, o OnePlus One possui uma tela de 5,5" e roda o sistema operacional CyanogenMod 12S, baseado no Android. Modelo "ONE A0001".
Dropped phone won't turn on
I dropped my phone from very long height , screen and glass looking good but no power on. may I know what could be the problem ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Best guess is something came loose on the inside and is now not operational, you could try to open it up and just get a visual on anything that might be out of place or disconnected, try re-seating everything, if that doesn't help the it will more than likely be the board
Esta resposta foi útil?
Pontuação 0
HI ! I had the same issue. I kept the phone in the freezer in an airtight bag for one hour and restarted. It worked !! (This was a method I saw in youtube videos) Hope it helps someone :)
Pontuação 0
1 comentário:
my phone is a One Plus
por
Adicionar a sua resposta
iamrajkumark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 30
Ao todo: 1,036
