Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 Perguntas Visualizar todos
Pergunta encerrada
LCD black after digitizer replacement?
LCD was working prior to replacement. Home button works, power button works, Siri comes on, can even hear picture taken when pushing the two at the same time, but the LCD is black/blank. No dim logo, nothing. I've plugged and unplugged the connectors several times with no change. LCD doesn't appear to be cracked or broken from removal, but could it still have been damaged without visual proof? I've tried hard reset, would a restore thru iTunes do any good? Please help! Thx
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you unplugged the lcd while it was displaying? In that case you might have damaged your motherboard. The iPad Mini is in many ways a very delicate device. Working on mini's, always power down, unplug battery and only then unplug lcd and digi.
It is common with iPads that you have to soft reset to get the back light working after repair. If that doesn't solve your problem, try changing the lcd. If that doesn't fix it, you damaged your mobo, probably because of disconnecting the lcd with image still displaying, or ipad still powered on.
It's possible to fix this, but you'll need to find a place that has an IR-solder station to replace IC's on the motherboard.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No the battery was actually dead when I started in it. But I unplugged it first anyway before unplugging anything else. I've ordered another LCD so I'll give that a shot. The LCD was a booger to get off the shield underneath it so maybe I did something to it. Idk. Thanks for the help
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 377
