Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone xr. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 6.
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
Esta é uma boa pergunta?
Pontuação 12
1 comentário
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Could just be the LCD. Clean the logic board and try another LCD
Esta resposta foi útil?
Pontuação 1
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
Pontuação 1
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
Pontuação 0
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
Pontuação 0
Adicionar a sua resposta
Joe Zhao será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 28,677
