2000 isuzu rodeo- v6 wont start w/o jump, cuts off while driving
My car wont start without a jump. Once I jump the car off it will run anywhere from 5 seconds to 15 minutes and then cut off and it has no power. The horn, lights or anything wont work. I've had the battery and alternator tested and they are both fine. What else could be wrong with it? I really don't want to spend a butt load of money. Someone said it could be a sensor but which sensor would cause the car to act this way?
Esta é uma boa pergunta?
1 comentário
Check the battery terminals to make sure they are tight and not oxidized(no white acid build up around terminals). If one battery terminal is loose and the ECU looses power for a second it shuts down and so will your car. Check your ignition color coils, if the car stops while running its loosing ignition gas or power from the battery. The last thing I would check is the fuel pump for proper fuel pressure.
My presumption without seeing the car is faulty ignition, alternator not recharging the battery, or loose or dirty battery terminals.
por Colin
