Ir para o conteúdo principal
O Moto G é o smartphone com preço econômico da Motorola. Ele possui todos os recursos que se poderia desejar em um smartphone, pela metade do preço. Números de modelo XT1032, XT1033 e XT1036.
Why is part of my replacement screen unresponsive?
I recently replaced my Moto G's screen with one I found on Amazon.com. For awhile (about 48 hours) it was working flawlessly. Then it started misbehaving. I noticed the touch screen responding poorly. I narrowed it down to one horizontal section of the screen just under the center as unresponsive. I downloaded a touch-test app and confirmed this was the case. However, this is not a permanent condition, as the area sometimes works randomly and other times is completely unresponsive.
Thinking it might be a loose connection, I took my phone apart again and checked the connections. I took the ribbon cables out and put them back in again after cleaning with alcohol. The problem persists.
What could be causing this dead section of my touch screen? And is there a way to fix it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Its possible the screen is defective, get a replacement and see if it does the same thing.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peter Pollet será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,610
