Ir para o conteúdo principal
How do I clean and repair the solenoid water valves?
I live in an area where the water has a high mineral content. The solenoid valves do not seat and leak. How do I access the valves? Can I dismantle and clean the valves? Are these valves a diaphragm or a spool valve? Can i fet parts or must the valve be replaced as a unit?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
the water valves are not very expensive - they may be available 2nd hand - try the scrappers
earlier machines may use identical parts
be very careful not to allow water to splash on or penetrate Motor Controller Panel etc
it could / will blow-up
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,416
