Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for MacBook Air models with 11-inch displays.
930 Perguntas Visualizar todos
Pergunta encerrada
Where is Fuse backlight a1370
Hello all
I search thé fuse backlight to my a1370 is i5 please looks thé picture thanks
Update
http://imageshack.com/a/img905/7933/SDtZ...
Update
Sorry thé fuse it s okay what is thé pin for test lvds ? Please
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Personne pour m aider ?
por
"No one to help me?" Give it some time, there are only about three people on the forum that will know about this, and I'm not one of them.
por
Remy, now you are going down a totally different rabbit hole. It sounds like you do not have a backlight. Connect an external monitor and see if that works. If it does you will have a totally different problem. You will need a schematic with board layout and at least a multimeter to check it out. You,'d be better off starting a completely new question instead of changing this one.
por
Hello
I havé test with externat monitor it okay for working and i have look thé lvds not problem no crack no damage but i want test pin because i think is led Blacklight
por
Adicionar um comentário
1 resposta
Solução escolhida
If you zoom in -right in the middle of your picture you'll see Resistor with R010 and 638ZF its to the right of it ,its has a Nice big "P" letter on it , it's a inline p link fuse hope that helps. With your multimeter connect both leads with battery disconnected and no charger if it reads open-zero current (infinite resistance) it's blown.
Esta resposta foi útil?
Pontuação 2
6 comentários:
John, can you be more specific, I'm not seeing it.
por
No problem, I just updated.
por
John, added an image to assist with this. Hope you do not mind. It's not about points, it's about helping out.....;-)
por
Thanks OT, not a very big P. No wonder I missed it.
por
Yeah I guess not , it looked big to me when I clicked zoom on the screen , I think what I mean was in terms of tiny components to have letters that visible its big , I'll work on it , thanks for the help OT .
por
Exibir mais 1 comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 615
