Ir para o conteúdo principal
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
Want to replace my mirror
Recently I have found some scratches on my mirror. I don't know how I did this. I want to change my mirror only not the whole box. Is it possible to change only mirror glass. If possible then how much does it take to replace????
Esta é uma boa pergunta?
Pontuação 0
2 comentários
you can buy a mirror box assembly on eBay, which is what I did .
I then removed the mirror and the mask from underneath the mirror and I then replaced the two items into the camera.
por
How did you go about removing the mirror and the mask from the box?
por
Adicionar um comentário
1 resposta
Solução escolhida
I have worked on a few of these cameras and getting parts is almost impossible. If you find them it will probably be on EBAY from a unit that is no longer functional. It would probably be more time effective and cheaper in the long run to just send it to Nikon for service. Taking this thing apart and getting to the mirror assembly is a 10/10 difficulty. Replacing the mirror is not for the inexperienced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Taufiq Imtiaz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 36
Ao todo: 2,177
