Ir para o conteúdo principal
Pergunta encerrada
External hard drive won't power on or show up in disk utility
Noob question: I've plugged my new 500GB hard drive into the external silicone case and plugged the attached USB cable into my mac. I would like to format it but it does not appear on may Macbook Pro.
The hard drive makes no noise and it does not show up in disk utility or in finder etc.
I did notice there was no power connector inside the silicone case. Is there a connector missing? - see pic below.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Try changing USB ports.
Esta resposta foi útil?
Pontuação 1
The larger connector is the power connector and the smaller one next to it is for the data. Does the drive work on or in another computer when not using the external case?
Pontuação 0
Mayer is right. Can I see the Sata connection again? You cut it off the second half of the pic
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 487
