Ir para o conteúdo principal
Pergunta encerrada
How to fix? Touchsreen fail after drop ,(Motherboard related)
Dear Ifixers,
I bought an iphone 6 from a costumer that had dropped his Iphone.
(factory phone, was never opened for repairs)
The drop caused the LCD to shatter, the housing etc. still looked good in
comparison with other iphone's that had a drop. (nothing extreme)
The problem is that the touchsreen doesn't work anymore, tried with other "100% working" LCD's so that is not the problem.
The problem is probably inside the motherboard. And that raises a couple off questions with me, I would be very gratefull if someone has an answer to these :s
-Does anyone had experience with this kind off problems ?
If so, wich part or chip on the motherboard takes care for the touch function ?
is this part replacable or fixible ?
I probably have to take my @%^ to a spezialized "microsoldering" shop to take care off this situation. Never sended motherboard in for repairs, so if anyone could help me out on this it would be amazing!
(Thanks for all those that are taking there time to answer all the questions on ifixit, they helped me more than once out when i started repairing. Hope to have the experience to do it with others some day.)
thank you
kind regards
Koen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If it is an issue with the motherboard, then you would have to be able to solder on the board which is very difficult. If you tried other screens then it is most likely something with the board. Check the digitizer and LCD prong connectors on the board and see if they are bent, if they are bent, then that is your issue and you would have to be able to solder a new connector onto the board, which again, is very difficult. You can purchase the connector from mengtor.com, which is were i purchase most of my parts for my repair shop. If you can get your hands on an OEM screen if you don't already have one , take some isopropyl alcohol and wipe the inside off the phone VERY lightly, i would recommend 99% purity so that you don't damage anything. All you are trying to do is remove your fingerprints. Do not wipe the battery because you will smear the letters and make it obvious that you were in the phone. Just wipe your fingerprints, they are usually on the metal only. So like the metal panels on the screen and the cover for the flex cables. Once you do that, take it to apple and see if it can be repaired. Another thing you can do is get your hands on an OEM screen and toss that on there and make sure everything is cleaned off any finger prints to erase all evidence, then put in on, take it to apple and say it doens't work.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 859
