Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Possible chip damage? Phone reboots every 2-4 minutes.
Hello,
A customer has brought me an iPhone 5C for power issues. Upon opening the iPhone I can see that the screen has been previously replaced. Phone appears to be clear of water damage.
The phone reboots every 2-4 minutes, either plugged in or not plugged into a charger. Replacing the battery makes no difference and restoring the phone through a DFU does not fix the issue.
I have managed to locate some board schematics but have not a clue which area and chips to look at.
Hope you can help.
Thank you kindly.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
same problem- you ever find a solution?
por
Unfortunately not yet. Definitely think this is chip related.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Bad battery or missing filter near battery connector
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your reply. I have tried a few batteries with the same result.
What am I looking for in terms of these filters?
Board examination is completely new to me.
Thank you!
por
I have same problem with iPhone 5c. I have three missing components. As in the picture at the top FL11 and the two below it. Jessa can you tell where I can find those replacement components. I have olso iPhone 4 donator board. In iPhone 4 chemantics there are FL11 but it still missing from every iPhone 4. There are many Fl components in iPhone 4. Is that same thing If I replace Fl11 with for example FL23?
por
The Filter you are looking for is FL11 and is extremely small. I've attached a picture with the filter circled in red.
Pontuação 2
check for any components knocked off around the battery connector. unplug battery and charging port to inspect. microscope is recommended
Pontuação 1
1 comentário:
Thank you. I will inspect under a microscope. Upon eye's view, the components seem to be okay when compared with another board.
por
Adicionar a sua resposta
zentech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 207
