will not turn on after having a power outage
my workforce will not power up after a power outage.
Esta é uma boa pergunta?
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Esta resposta foi útil?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 17
Duração total: 5,096
1 comentário
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
por Tyler Momberger
