Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
407 Perguntas Visualizar todos
Problem with screen replacement image too high /\ components problem?
It's an A1509 ipod (16GB, no camera)
A picture is worth a thousand words so you'd understand the problem ... I haven't tried to restore or else by itunes because I can't unlock the device (because desactivated) to authorize/rely the ipod (I dunno how to say in english when it's the first time you connect device to a computer) and home button isn't working anymore ^^ thanks for help !
pic 1
pic 2
the touch screen seems to be ok because when i press in the right place of cancel button in the bottom it works ....
the vertical seems to be too high (well a zoom but only on the height ...)
Update
Ok, my friend told me that it wasn't drop in water, but may be some mud on it, I've found a little dirt over some components, I've "cleaned" with a needle ... and turn on again, not helped ... :P :( help please !
http://imgur.com/JgED2TX
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Anyone for help ? ^^ if it's not working anymore without changing a component tell me so :P :)
por
Adicionar um comentário
1 Resposta
tap the screen three time with 4 fingers.
Esta resposta foi útil?
Pontuação 0
Comentários:
Are you serious ? You well see that's not a zoom ! And it's with 3 fingers normally.
(And I've already tested this of course !)
por
Please I need help for this !
por
Adicionar a sua resposta
N Halden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 83
