Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
"No SIM" after reassembly (water damage -> alcohol soak, new battery)
My iPhone 5s fell in the pool. Tried to dry it out by letting it sit for 72 hours in rice, but the phone was still stuck in a boot loop.
So I ordered a new ifixit battery, disassembled, soaked the logic board in isopropyl alcohol, dried it, installed new battery and reassembled the phone. And it works (almost) perfectly, except it does not recognize the (good) SIM card (as tested in another phone).
I've tried resetting network settings. The phone still has an IMEI displayed, so I don't think it's fried. Is the SIM socket particularly prone to hiding droplets of water/alcohol? Can the socket itself be replaced without de-soldering?
Any advice appreciated!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Have set the time and date? Should be done automatically if the phone is connected to WiFi
Don't know if this fix your problem but it's a solution for the known "searching" problem :p
-Alex
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ccc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 219
