Ir para o conteúdo principal
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 Perguntas Visualizar todos
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
Esta é uma boa pergunta?
Pontuação 16
3 comentários
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
por
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
por
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
Esta resposta foi útil?
Pontuação 3
2 comentários:
ASUS provide zip file and when we run this command it says missing text files
por
can you give more detailed information ?
por
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
Pontuação 1
Mei tablet bringt das soeben was tun
Pontuação 0
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
Pontuação 0
forgot screen pattern of phone
Pontuação 0
Adicionar a sua resposta
linda2222 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 54
Duração total: 20,621
