Ir para o conteúdo principal
The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
Screen goes black after startup
On starting up all the normal views appear on the screen, the apple logo, blue screen etc then the desktop appears for about a second then the screen goes black. The monitor power light flashes indicating that there is no signal from video card. Anyone any ideas ? I am suspecting either the power supply or the video card but would be delighted to hear from anyone that has had this issue and how to diagnose.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Did you get a resolution?
por
Adicionar um comentário
3 respostas
Try Replacing your GPU, Clean the contacts of the card, Change the slots, this would be the first step towards the repair,
And if still doesn't work try re installing your OS
Message me back if you still face any problem
Esta resposta foi útil?
Pontuação 0
I have the same problem on my Power Mac G5 2.5 ghz DP Quad.
I have changed the video card, not the video card. That has been tested.
When I power on the computer always chimes.
When I have no hard drive cables plugged in I get video, 99%.
Sometimes I have to reset the Power Management, unplug, press reset, remove battery, power on, turn off
then insert battery and power on again.
I am thinking maybe the cables.
The worse scenario would be to have to replace the processor or the logic board.
One successful time with the hard drive plugged in I got video for about 5 min.
Then the video went away. I am going to test all the cables first.
I am beginning to think the processor.
Pontuação 0
1 comentário:
It may be a software issue. I'm also having this problem with a MacPro & Mini Mac. I zapped the PRAM and the Mini has been on for a day now. What operating system are you running?
por
If I boot into safe mode, I can use the G5 with limited functionality due to safe mode; BUT everything works in safe mode. I get video, audio, I can manage files etc. It’s only when I boot normally, I hear the chime, I get to the desktop, but seconds later, the screen goes black, and monitor shuts off indicating no signal going to the monitor. Once again, if I boot into safe mode, everyworks. Really baffled, not finding much help online either.
Pontuação 0
Adicionar a sua resposta
declan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 1,252
