Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Perguntas Visualizar todos
Can I replace a disconnected battery connector?
While trying to install the new battery I must have put to much pressure on the brown connector(step 5, Installing new battery). I now have several pins showing and a connection line on the base of the connector. I don't see any way. I'm hoping someone has a good idea.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
the connector must be soldered to the board - that's the only way to handle that problem.
try to find a cell phone repair shop in your area - most of them are able to resolder the connector to the board.
surely they don't do that for free - but they are normally the only ones who are willing to do that repair (and have the right tools and knowledge)
i did that repair for others too - so try to find someone in your area/country and the ipod could be revived
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks, that's something I hadn't thought of. If I can find a shop in a reasonable distance I'll give it a try.
por
Adicionar a sua resposta
terrymcu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,431
