Ir para o conteúdo principal
How do I get the ipod to unlock?
The hold button appears to be broken in the locked position. The switch moves but does not unlock the ipod.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
Well....
A couple of reasons why this may happen:
  1. the little nubs on the hold switch are broken off. It is housed on the front panel.
  2. the hold switch itself is broken off. It is housed on the logic board.
Either way, it seems like you need to open up your iPod, unfortunately.
Unfortunately, these machines are NOT easy to get into. They have very delicate clips around the outside that make getting a new rear panel almost a necessity whenever replacing anything else. Just wanted you to know beforehand, so you're not surprised.
Take heart, it can be done! Good luck!
Esta resposta foi útil?
Pontuação 2
How do I unlock iPad mini 4
Pontuação 0
I sm asked for a combination
Pontuação -1
1 comentário:
This isn't really an answer. Please delete this or edit it to answer the question.
por
I forgot my code and now can not unlock my iPod ????
Pontuação -1
Adicionar a sua resposta
Jennifer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 4,427
